I have a seaward s700 water heater which is hooked up to 120 v electric but has never been hooked up to the heat exchanger. It has one continuous hose that leads to each of the heat exchanger fittings on the rear of the water heater to keep it clear of trash, etc.
This weekend I decided to finally hook it to the motor exchanger to have hot water when motoring. I disconnected the hose from one fitting and tried to blow through the exchanger to assure it is clear. I couldn't blow through it. I also tried to blow the other direction and again nothing. It appears to be stopped up where the motors coolant should flow through the water heater exchanger. The hose is clear.
Am I overlooking something? Why can't I blow through the water heater exchanger?
Thanks, Greg.
Thanks, Greg.
