Many of the older unit manuals and other data was lost when the roof caved due to a severe storm. I do not recall seeing an owner’ Manual on that boat. If you go back to top of all hunter owners, there is reference to older documents. There may be something there but if not, I don’t you will find anything. The first 19 stopped production as a kit boat around 1984
And/Or - do you know if the process for stepping the mast, with the helper pole, etc, is the same for this one as the process in the manual referenced above for the water ballast boat?Crazy Dave Condon.............is there another similar non-ballast Hunter around that size that would be applicable as an owner's manual and provide operating guidance for the OP?
