Sean
  • Thread starter Mark Cooper - Caribbean Soul
  • Start date
Did you find your leak? I gave you another suggestion and am curious if you found the same thing as I'm wondering if this isn't something ALL 240 owners need to look at. Mark
Sean
Leak
Mark I haven't been able to check. I'm hoping Sunday to check this out. I haven't found any specs in reviewing the owners manual for a tourque setting. I'm going to just snug them down if they are loose. I did check the loop on my bilge pump and it is as hight as it could be. I also checked the through hull fitting for the sink, and It appears to be fine. I hope this is the trick, because I enjoyed a dry bilge alot more than what I got now. All total the water was maybe 3/4 of a quart, but it was found in the starboard bilge as well as the aft bilge.
