I recently moved to a berth in San Francisco in a double slip with a port side tie and another boat to starboard about 2 feet away. The prevailing wind is almost directly abeam at 90 degrees and often 10-15 knots. I have learned how to handle coming in to the slip with the crosswind- by having more steerageway than normal and pointing the bow at the dock rather than trying to come stright in as I would without the crosswind.But the next question is how to gracefully leave the slip with the crosswind blowing from the same dirction. The problem is that as soon as the bow line is released the bow will blow over into the neighboring boat. If I back out of the slip I'm concerned about the stern being blown up the channel in the wrong direction before I can get steerageway in reverse.Any of you who have worked out a reliable method for leaving a slip when you have to back out with a 10-15 knot crosswind blowing you directly into the downwind boat in the slip and a relatively narrow channel behind you?
