L
Laurie
After reading these threads about water in the bilge, here is my related question that perhaps someone can give me some ideas or direction to go. When I bought my 1973 C22 last spring, it was filled with water throughout the bilge and every compartment (previous owner left the companionway door off for a season as it sat in his yard on a trailer, incredible buy anyway). I pumped/sponged the water that I could see out, but it continued to weep out of the cracks (like gelcoat cracks, with some sections missing too) for a few weeks. I'm not sure why this surface is all cracked; I assume the boat's age and expansion/shrinkage over the years. Eventually I got everything dry after lowering the bow, then the stern, on the trailer, so it drained out of the lower sections I couldn't see. I want to seal this finishing layer again, whatever it is, so that if I have water inside again for some reason (like cleaning), I don't want to go through this same routine. I also worry what it could do to my hull, if the water soaked in long enough. Any thoughts? What is the layer made of that lines the bilge/compartment areas anyway? Thanks for the any input!LaurieC22 #2250- "Carpe Diem"
