My Cal 27 was converted to outboard power in 2004 when the inboard diesel died. I removed the iron hunk last year, and now that I'm on the hard for bottom paint it's time to seal the shaft log. I cut the SS shaft and pulled it and the stuffing box off the inside. I cut off the bronze strut basically flush so that it can be painted over.
My original thought was to use a new stuffing box rubber hose with a bronze barbed fitting and clamps plus a bronze cap sealed with 4200 and clamped to the log inside. A non-leaking stuffing-box alternative. This seems like it might be all that is needed, since the old shaft and stuffing box have kept water out of the boat since 2004.
The boat yard suggested 8-hours ($130 per plus supplies) to epoxy and glass over the openings at both ends of the shaft log. How long can grinding a bit of gelcoat and bottom paint off the 1.25" ID tube and then placing some glass and epoxy really take. Seems overkill for a $6,000 boat.
While at the marine hardware store (Fisheries Seattle) I spotted the tapered hole plugs and an idea was born that maybe two of these and some 4200 are really all it needs. Clean up both tube openings a bit, and slather up the plug with 4200 and tap it into the holes. When cured trim off the inside, and that is done, on the outside trim to the gelcoat line and then either simply bottom paint over it or maybe apply a bit of epoxy to the exposed wood with or without some glass also. If these plugs keep out water in holes in wood boats, having two is really overkill maybe, and the inside is just backup.
What do others think about this water sealing project.
Thanks, Rick
Thanks, Rick
