ports and propane stoves.
Hi all...seems like everyone goes thru these things at some point. I , too, replaced my stove with propane, a Force 10 unit. I created a proper locker in the stern seat locker by dividing it up with a glassed in partition, and made it isolated from the rest of the boat. Just drilled in a small thru-hull in the transom for a vent, and presto, instant locker. OK, not instant, but pretty quick! I found that certical mounted tanks wouldn't fit, so I got 2 horizontal mounted aluminum tanks. The aluminum was a bit more pricey, but they won't corrode. I measured all the runs for propane lines and had them made up, bought a regulator and gauge, plumbed it all in, and it works perfectly. I also run a Force 10 heater, and Paloma instant hot-water system. Propane is the only way to go. It's clean and safe, the only dawback being the moisture created by burning propane. Leaving the companionway open when cooking helps, as does the "Envirofan" I got for the heater. What an exquisite unit. No electricity, it just sits on the top of the heater, and the heat generates the juice to drive the fan! Perfect for the 12v Nazi in me! It circulates the air in the boat, creating an evenly heated, relatively dry, environment. Up here in BC's Gulf of Georgia, where I do the majority of my sailing, it extends my season to year-round. As for the ports, remove 'em, clean up the holes, epoxy what you can, replace material if you have to, use LOTS of sikaflex when you put them back in, and keep your fingers crossed!Cheers!!CapnArtS/V Aloha 1Vancouver, BC
