This is a Porta Potti.
I assume that you can disconnect the pump out connection , place a cover on it ....and dump it over the side..3 miles out, in open water..
If anyone has seen one or has one , can this be done?
Dan Vega 1240
Wel, it wasnt what i meant, maybe I didnt explain wel. I was interested if the pump out, which is meant to be conected to a deck outlet, could be connected to a underwaterline pump out, just like you do on a "normal" head with a holding tank.
