Couple questions:On a Hunter 35, 1988, the rudder shaft is open at the top and exposed to water and dirt that can build up inside. Question #1: Should I seal the top of the shaft by, say, squirting some foam in it? All it would take is some foam near the top where the quadrant attaches.Question #2: Where the shaft enters the top of the rudder it looks like there is a potential for water to get inside. Is it permissible to put a bead of epoxy around the joint? I'm concerned about causing oxygen deprivation.Question #3: Not related to the above; should the rudder shaft be "grounded" to the rest of the boat?
