The seacock that has a yellow lever, inside the starboard lazarette, is stuck
I think it is the one that brings the sea water to flush the head
One day, when I get the boat out to do the bottom, will replace, but for now, what do I use to loosen it?
I don't want to put too much strain on it, but maybe if I use some thing I could lubricate it and then it will work OK
I am not sure if it has a lver or a valve,now that I think about it
What do you think?
While I am about it, I should lubricate all. I know there is one under the locker port side, halfway: where are the others?
Anyone with a H33 (82) ?
What do you think?
