Spray lubricant
I also have a 2000 H340 with the same seacocks - I assume. Mine are all bronze and I lubricate them every spring by spraying some pressurized white (lithium) lubricant outside the hull and up through the thru hulls into the valves. I then go on board and exercise each valve. The seacocks for the A/C raw water intake, the intake for the head and for the engine raw cooling water each have a 90 degree elbow on the thru hull with the seacock attached to that followed by a Sherwood 3/4" seawater filter. This makes it hard to get any lubricant to the seacock itself from either inside or outside the hull. (the head intake has no filter). After 12 years of service, all the valves seem to be working well with no binding.
