Water-Pump Lub'
Water-Pump Grease also works well (as does lithium, etc) for Seacock Lubrication. You may want to consider food-grade lubricants if any of the Seacocks supply water to the Galley. (I often use seawater in cooking)ie - goto:http://www.forsythe.on.ca/fhg2.htmland select:Forsythe FHG-2 Grease - Food Grade greaseGroco recommends eith Teflon (TFE) or Silicone Grease.http://www.groco.net/parts/data/574.pdfRegards,Gord
