Refrigeration Aux Pump
I just discussed this with another 376 owner and our service manager after his pump went out. We all agreed it's very expensive to replace that particular pump...it's a magnetic induction pump and the motor compartment is sealed. The impeller shaft seems either to get worn in its slot or scale builds up. Either way, the induction motor isn't strong enough to overcome the shaft drag so it quits. He tried to clean it to no avail.We all agreed that it would be nice to find some other less expensive replacement pump and the idea of a bait live well pump came up. It would have to be the type that has both inlet and outlet hose ports, obviously. Last time I saw him he was walking through Marsh Harbour trying to find just such a pump. Don't know whether he was successful or not. Also, I can't answer the question of how large a pump is safe. Maybe Kenyon Marine has the answer.The operating manual of the Super Cold Machine recommends switching on the aux cooling pump anytime the ambient air temp goes above 90 F. It's on a sensor, I believe, so it comes on on demand. (That would explain the sporadic operation of your pump.) Unfortuately, because of the compressor location in the 376 it's over 90 F. just about all the time in the Bahamas. We wired my pump so it runs anytime the fridge compressor comes on to help overcome the heat buildup in the compressor compartment. So far, no pump problems after 7 months. The other owner doesn't do that because his boat is kept in an area where there is a lot of sea grass and debris and a continuously running pump would clog the sea strainer too often.Hope this helps clear things up.
