C
Chuck
I just purchased a Cat 30 and am new to ownership. As the boat was hauled out of the water, I noticed a thru-hull fitting which protrudes from the bottom and looks like a strainer. I regarded this as the intake for the sea water used to cool the engine. Upon closer inspection I noticed that there appear to be dried fibers of some sort packed together in a dense form inside this "strainer". Is this a filter of some sort and if so, does it require servicing and how often?Thanks so much,-Chuck
