running on hard not good enough
Hello,IMHO, if you are going to spend any amount of dough on this boat, you really want to splash it and make a test run. Sure, you can run a hose to the motor and run it, but you can't test the transmission, and you can't run it under load. You really need to know that the engine will run, the transmission engage in forward and reverse, that the engine will run at the higher RPM without overheating, that it doesn't blow smoke at high RPM, etc.Regarding who pays, typically (and every deal can be different, but TYPICALLY), the boat owner is responsible for having the boat in the water and ready to be demonstrated. If you decide not to purchase the boat, you are responsible for paying to restore the boat to pre-survey condition. Here's a simple example:I bought my boat last June. It was on the hard. The owners contract with the yard covered launching the boat. My surveyor examined the boat in the hard, then the boat was launched and we did the sea test. If I decided not to buy the boat, I would have been responsible for paying the hard to haul and block the boat. I did end up buying the boat, so I just sailed it home.Regarding bottom paint and other things like that, that is really up to you. If you want fresh paint, then it would be your responsibity to pay for it.Good luck!Barry
