batteries, scuppers and listing ... oh my
Thanks guys. I appreciate your help.I purchased the boat locally; Oak Harbor, WA. It was "Brassbounder." Does Seattle have a Hunter's Club where Hunter Owners commune. I was thinking about gluing/glassing some wood frames onto the inside of the bilge, and securing a removeable shelf, on which the batteries would sit (as Richard's link shows). When I need to get to the bilge I can pull out the batteries and the shelf for good access to the bilge. It's great to know others have done it successfully. Thank you.Regarding the starboard list, I checked my tanks and they are all equally full ... well, all are half full. The only variable is the waste tank; I don't know how full it is. Even so, I'm not sure the batteries, in their current location (bottom of the starborad lazarette), or a full waste tank should make the boat list. I've emptied the boat completely of gear. I'll keep you posted.The deck scuppers are all easily accessible and the leaks appear to be at the hose-scupper joint, an easy enough fix. I'm probably overthinking this, but I see potential for abuse to the hose causing damage to the hull/deck where the scupper is attached; in addition to the leaks I'm already experiencing. I figured the scuppers were positioned secondary to a low spot in the deck, but I'm not convinced the scupper-cure is better than the low-spot problem. I purchased some drain plugs for the scuppers and I will let you know the results.Thanks again for all your help ... tj
