What is the scupper hose size for a 27 foot 1977 Hunter?
The following discussion may only make sense to a 27 77 Hunter owner.
There is 2 inches of water in my bilge following a hard rain. This occurs both during on shore and in water storage. There has never been any evidence of water moisture inside the cabin. But since most of the water is located in the forward sections of the bilge, I didn't suspect the scupper hoses. It will be easier to understand this comment if you have seen the interior bilge construction. But something must be leaking. There is no evidence of water leaking onto the mast support beam when the cabin head mast box is removed. This has annoyed me to the point of having to find the source of the leak. So I will start by replacing the scupper hoses and check the scupper fittings. I checked the starboard hoses which are resting on large blocks of foam to protect from chafe. Following a hard overnight rain, the foam blocks and area around the hoses where dry. But I still need to check the port side hoses. Got my fingers crossed.
Thanks,
Howie
Thanks,
Howie
