the biggest problem keeping a tank onboard...
...is that everyone in the marina knew about it after a few years, and if anyone dropped a pair of sunglasses, or a wrench, or a set of keys overboard, I'd be the one asked to retrieve it. And some folks can't understand why I wouldn't want to burn up an $8.00 air fill searching for a $6.00 wrench. Easier just to keep your tanks in the garage.Jack, I'm a retired scuba instructor, both PADI and NAUI certified, and I gotta tell you, judging from your use of terminology ("googles," "oxygen tank") you might want to consider taking a refresher course, assuming you're actually certified. Honestly, anyone completing open water certification should already know about the need to have tanks VIPed yearly. Your instructor will tell you all you need to know about proper tank storage and maintenance, as well as familiarize you with the proper procedures for boat diving. Meanwhile, it's a really bad idea to solicit advice on scuba on an internet forum. Competent, professional advice is not all that costly, and the lack of it might be.By way of example, one need read no further than Ken's do-it-yourself hooka. That's a really dangerous idea. For example, if you don't know enough to get an oil-free compressor, something Ken doesn't mention, you'll end up with Lipoid Pneumonia, which can be fatal. And that's only one of the serious safety problems that his set-up will result in.
