So I built new forward shrouds. looked up the specs and misread the number of crimps 1/8 sleeves. Currently each sleeve have two presses, calls for three. (lord knows how I mixed that up). Searched the net for an answer to these questions with no luck.
1.) is two presses across two sleeves sufficient? (doubtful)
2.) can sleeves be repressed once pressed (add a crimp)
3.) if not, once sleeves are removed can the same spot on the wire be recrimped with new sleeve.
throwing myself at the mercy of the court, but if I am asking these questions someone else must have/ will do the same thing as I did.
