scratch repair
20
MacGregor 26S Alberta
I have a '92 26S with a scratch right down to the fibreglass above the waterline. Believe I have the factory hull coating. What is it likely to be and how fix? If this is already covered please point me to the source. I live far from a marine supplier and/or expertise so product names etc. would be a big help.
Thanks.
tjar
Aug 8, 2011
166
Hunter Legend 35.5 Tacoma, WA
I just finished repairing several scratches on my 26D and it wasn't as intimidating as I imagined. I did spend some time on Google and You Tube looking up videos and tips. Some of the key items that I learned are:
1. Prepare the area by sanding. Gelcoat does not penetrate spider cracks, so use a pointed can opener or Dremel tool to make the scratch deep enough for gelcoat to fill up the space.
2. Clean the area thoroughly with acetone
3. Use masking tape right along the area to be repaired. By taping closely along both sides of the scratch, you can fill the scratch and use a plastic scraper leave the gelcoat just slightly proud of the surface to minimize sanding.
4. I used Evercoat Marine Premium Gel-Kote polyester gelcoat product from the hardware store that worked OK. In hindsight, I should have purchased a thicker product since the scratch was fairly deep and required two coats to fill it.
5. After allowing the gelcoat to set about 20 min, coat it with Mold Release to seal out the air, or apply cellophane or wax paper to seal it. Otherwise, the gelcoat will not hard cure and will remain tacky.
6. Sand thoroughly using a sanding block with 500, 1,000 and 1,200 grit wet sandpaper. Pinish off the entire area with polishing compound and then rewax the area.
The scratches are barely visible, just slightly whiter than the surrounding fiberglass. They should eventually fade and match the rest of the boat, but I have some older repairs that are stii visible. You can try adding some color to the gelcoat, but that seems riskier trying to get a perfect match.
Jan 4, 2006
7,149
I have Used Tjar's Procedure and ....................
................... had excellent results. I'm lucky in that my gel coat is the same colour as any pure white gel coat. Repairs are invisible.
The only change I would suggest is to use waxed gel coat. It sets in air (without covering) which makes the procedure much simpler.
Aug 26, 2013
20
Thanks a bunch. Could you give me a Canadian supplier for these products?
Likely hard to find in dry Alberta.
May 4, 2005
4,062
in Ft lauderdale there is a marine fiberglass store that computer matches gelcote. $50/pint with or without wax. the old timers use to use cigarette ashes and white gelcote.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Are they still in business and if so do you have contact info ? Thanks
Regards
Woody
Dec 8, 2007
303
-mac 26M -26M tucson-san carlos mx
Come on!! your not serious are you.. obviously you have a computer because your on this forum. You gotta know about the internet, UPS delivery, Goggle search, West Marine.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
if this was directed to me ...it may not have occerd to you that i was looking for pint quanity not quarts whitch is what most want to sell and also charge $85 dollar matching fee......
regards
woody
May 4, 2005
4,062
^ does west marine have this equipment too?
fwiw I bought mine in 2005, so price is probably a bit higher today.
(I had no idea it was even possible..... for colored hulls it would be priceless)
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
I've got gelcaot and wax and resin all from a local boat repair place here in London Ont. (Heritage Marine) They are very helpful and will sell me what I want in what ever quantity I want. ( I got black gelcaot in a old olive jar last time because that's all I needed. They poured it out of a 1 gal container for me.) That's service.
When the time comes to repair tjar has it on the money.
Check out boatworkstoday on youtube too for great info.
Pictures are some repairs I have yet to do.
tjar
Aug 8, 2011
166
Finding, your first picture looks like you may have a stress fracture with some underlying structural damage to the fiberglass. If you just slap on some new gelcoat to cover it up, you may end up doing the repair again. You might want to look into laying up some new fiberglass cloth before putting on the gelcoat. Again, the internet is your best friend for "how to" videos.
