Doug T.
*sigh*Blisters. No, that's not really the right term to describe these things. Imagine huge swaths of hull that are riddled with open, oozing, acidic sores. You grind them, looking for solid fiberglass, going deeper... deeper... finally hitting air before you're done. You grit your teeth and plane the gelcoat off the entire bottom, figuring that it can't be THAT bad all over the bottom. Can it? Uh... yes -- it can. The entire hull is involved -- not a clear patch anywhere. This is not a gelcoat problem -- it's one, two, three layers deep into the fiberglass all over the place.The only way to salvage this boat is to, basically, put a new hull on it. The boat yard says it needs three full layers of glass to make it structurally sound. They want $7,500. They guarantee it for 10 years, but why would anyone put that kind of money into a boat that they bought for $4,300? It's not as if the rest of the boat is in great shape. The deck has numerous large, rotton, soft spots, it leaks like a seive in the rain, the electrical system is crap, and it's slow as a dog (an old dog) when sailing. Adding three layers of fiberglass vinylester is NOT going to make this beast any lighter or faster.Sorry -- maybe we just got the biggest lemon of the bunch, but it's just not worth keeping.So... It's going to the scrap heap. Any and all parts are available for sale. Need a toerail? A mast? Parts for your Yanmar SB8? (The starter/solenoid is brand new.) Winches? Boom? Tanks? Swim ladder? Tiller? Prop? Keel? Etcetera, etcetera, etcetera. We're going to clean out all the stuff we want next weekend. We're going to call the boat disposal folks a couple of weeks after that. First come, first serve. We're buying an '81 Sabre 28. It's in great condition and the quality is 400% better than the same era Hunters. Yes, they're more expensive, but it looks like it will be worth every penny. (How many 27' Hunters come with Lewmar 40C ST jib sheet winches?) (Another redeeming factor is that the brand new North sails that we bought for the Hunter -- main
