Scantlings
  • Thread starter Al - s/v Persephone
  • Start date
A
Al - s/v Persephone
I recently heard a supposed rule-of-thumb for FRP hull scantlings that said 0.01 inch of thickness at the waterline for each 1 ft of LWL, with "10-to-15%" greater thickness at the bottom and 10% thinner at the sheerline. (It supposedly applied to modern low-resin vacuum-bagged hulls vs older high-resin-content hulls.) Has anyone else ever heard of this, and - more importantly - do any naval architects or boat-builders here agree with it as sufficient for open water?
Ross
Jun 15, 2004
14,693
.300 thick on a thrirty foot
sea going boat? I wouldn't trust it unless it had a very well laid out frame. I live by the adage "that nothing too strong ever broke."
C
Capt Ron;-)
Scimping on Scantlings
Al, I don't know the answer, probably shouldn't even be wasting ink here. The fRP use to be much thicker, stronger, but heavier too. They found that glass is much stronger than had been originally thought, engineered, and have been making them thinner; I could see the waves sillouetted against the hull of a 36 ft Hunter from teh aft cabin. The stringers and ribs give more strength than the skin, but I am with Ross here; I like a strong hull under me. They make racing hulls very thin nowadays, could those be scantlings for race boats?
Ross
Jun 15, 2004
14,693
There was a picture
of a large racing sailboat that had folded just aft of the companion bulkhead in ten foot seas. It was light! probably too light.
