Steve Buckton
The SB8 in my H-27 is getting long in the tooth. Power and speed has dropped (~3kts top speed...not good). I had a new injector installed last year as well as a lot of fiddling with the govenor & throttle setups. Compression is still good. Is this original engine just tired out or is there anything else I can do? Also if I go the replacement route what engine(s) would you reccomend? Many thanks...this is a great forum!Steve BucktonVancouver, BC
