Another Two Cents Worth
RussellI couldn't help but put in a plug for Peggie's advice on the SeaLand Odorsafe. After we refit our Hunter 27 with that hose, the head odors have virtually disappeared. And the summer heat can be brutal down here, so I think it's a good test.However, as she mentions, it is extremely hard to work with in terms of stiffness. We were able to get it around the corners without heating, but not onto the pumpout fitting under the deck. We found it necessary to gently heat the end of the hose with a blow dryer until it was warm to the touch (Peggie may not agree, so we'll see what she says after she reads this). Then lubricate it with a water soluble lube (I think I used KY, actually) and push hard! The most difficult part of attaching the hose to the pumpout fitting was getting access to that fitting. It was inside a hanging locker. But after heating, lubing, and cussing quite a bit, we got it on there and it's been good for almost two years now.Anyway, the OdorSafe stuff is great, and as far as the leftover 'waste material' (more politically correct) in the hose after pumpout, we simply follow Peggie's advice (again) and thouroughly rinse the holding tank twice or three times during the pumpout routine. Then drop some KO in there and all is well.Good luck with the re-hosing, and remember to be patient!Ron Vanderveer and Tom Hrkach
