Sandpiper 565 1980 : New owner Qs
1
CL Sandpiper Bayfield
Hello, Just bought a 1980 Sandpiper. Here are the questions I have: 1 The trailer has 840 pound tires on it, which need to be replaced. Is this the correct load rating for the trailer? Seems a bit tight for the boat weight + trailer 2 The trailer is pretty solid, but has unusual construction. It has coil springs (a bit flattened) and shock absorbers (they are GONE). Anyone have a similar trailer? Did you ever replace the coil springs and or shocks? If so, what parts did you use? If you have an original trailer, I would appreciate a pic. 3 I have a few nicks on the boat. I would like to repair them, and make the repair seamless. My boat is beige. Is there anyway to buy gelcoat and get it colour matched? Thx for your help
E
Eric, former S565 owner
Does seem to b lightweight
Hi Mangler. #1 I would agree that your trailer is a bit under sized. The spec weight for a Sandpiper is 1200#. That doesn't include for motor, gear, sails cushions etc, etc. Plus you need to add the weight of the trailer. You may be able to find a nameplate on the trailer that will give you the capicity. I once weighed my boat, motor, trailer, with all my gear, and I was surprised it weighed 2000#. My tailer was a bit oversized in my case, and heavier. #2 I have no experience with. #3 You can buy colour matching gelcoat kits. Mix up your color and hope it works. I think you'll always see the patch, but the nick will be gone. That's called a 6ft patch. Can't see it from 6 ft away:) Eric
