saloon wood table replacement
grevay
Sep 23, 2007
7
- - falmouth, me
I am looking to replace our dining table in our new beneteau 43. The laminated table top has become scratched quite easily and we would like to replace it with a marine grade finish wood table top. Any suggestions for resources that won't sink our boat?
Rick D
Jun 14, 2008
7,204
Polyurethane Finish?
Some polyurethane finishes are quite hard and scratch resistant. Did you try a major refinish? If so, see the wood advertised on this site for the cockpit table. Looks like a good compromise as material for a custom table if what you have is teak.
Tim R.
May 27, 2004
3,626
Varathane
Is supposedly one of the hardest oil based polys out there. It has worked well for me. I would go to Atlantic hardwoods and have them join some 3/4" teak to the rough size that you need. get it home and cut it to your size and apply the finish. I saw a big Bene sailing around Portland harbor this weekend. Was that you?
RichH
Feb 14, 2005
4,773
BAR-TOP varnish !!!!
Very HARD varnish and not flexible/ding-able like a flexible 'spar' varnish. You usually have to find an ancient paint store with the proprietor older than god ... and he will/make it for you. This is not an 'easy varnish' to work as it takes several coats and the last few have to be flat sanded with 1000 grit---> 2000 (or finer if you can find it) grit paper and/or the last coat has to be 'hand rubbed' with mixture of 'rottenstone' and water (the heat from hand rubbing will develop the glowing irridescent 'patina' of the wood .... OR/then high-speed buffed with a knobby foam pad and 3M "Perfection" buffing compound. Such a surface is 'bombproof' and totally resists 'watermarks', etc. If you want a satin surface, use oil (instead of water) & "rottenstone' with a little bit of pumice added. Do websearch for "BARTOP varnish".
