salon window leaking
Jul 28, 2015
2
beneteau 423 Baldwinsville
My 2006 beneteau 423 main salon window is leaking do they make a replacement gasket or is there a fix? Skylight window around 16 inches wide and 6 feet long. It has some give in corner when pressure is applied.
Beneteau 343 Saint Helens, Oregon OR
If similar to my 343, the panorama is first glued in then caulked. I am about to recaulk mine again. One of the 343 owners got a dealer fix that used marine batteries to help hold the glazing down while glued. The factory fix then went to screws with fender washers that were removed after the glue set.
I know of no way to remove the glazing short of destruction.
Sika has a manual for caulking marine glazing.
I used sika products on mine.
Try contacting Beneteau or a knowledgeable dealer.
Oct 28, 2021
55
Beneteau 323 Wiarton
Any updates? Similar problem with our 323. Curious what black gasket/glue is used prior to silicone.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Likes: nitrogenase
