Salon Table Heat Damage
1
- - Herrington Harbor, MD
I have heat damaage to my salon table from hot food on a paper plate. The table turned white under the plate. Any ideas how to fix the problem!
Jul 17, 2005
586
Hunter 37.5 Bainbridge Island - West of Seattle
Don't sand it, not very much anyway.
I had some nasty water stains on mine. I sanded it and shortly the top layer was getting pretty thin, so I quickly stopped. I then applied a number of coats of teak oil. It looks ok now, but not as good as before the water stain. Obviously. I also would like to hear what others have done to their table.
Dec 25, 2000
6,051
Hi Rbuchen, the white discoloration you...
reference is most likely damage to the table's finish coat. I would contact Hunter Marine to find out what they used, but it is probably lacquer based, a very durable plastic coating. It is an easy repair. If it is lacquer you will need to sand the finish until you get below the discoloration, which may mean bare wood. You can get lacquer in a spray can from most home improvement stores, like Home Depot. Prepare the surface around the sanded area by using a furniture cleaner to remove any waxes, oils, dirt, etc. Then spray on several light coats (seven to ten) of lacquer on and around the damaged spot. Lacquer is fast drying as long as the environment is dry and warm. Check the surface for nibs (specks of dust) before applying succeeding coats. If you feel any use a 320 grit sandpaper to remove them before the next coat. I think you will be pleased with the outcome. Terry
Jerry Clark H356 SV Persistence
Hunter finish
The same thing happened to our table shortly after we got our 2003 356. At the Miami boat show, I talked to Hunter rep and he showed me a can of "spay finish" that is shipped with each boatfor touching up. When I got home, my dealer gave me a can and I just sprayed it on the white spot! No work at all and it was fixed! Do not sand, just spay on. Works for other small blemishes also. You do need good ventilation.
Mar 20, 2004
1,753
white stain cure
Another fix that's been used for a long time for this kind of heat/water damage is to cover the spot with mayonaise (yes, real mayo!) and let it sit for 1/2-1 hour, then rub off. if any of the mark remains, repeat.
Oct 3, 2005
159
Catalina 387 Hampton, VA
woodworking knowledge
Lacquer is a solvent based finish that can be renewed with thinner, unlike poly which once cured is set for life. This is the same with shellac, but shellac dissolves with any alcohol.
