I wanted to order a set of new sails (93 26 s) I have been talking back and forth with Judy B. She has been quite helpful. Her reply:
I can build you the same mainsail that I built for the last two Mac 26 classics I did.
Luff 24.67'
Foot 10.25'
Leech 26.2'
Tack offset back 0.5"
Tack offset up 1"
Sail feed height: unknown - you'll have to supply this dimension if you want to avoid having to take slides out when you reef. Or we can take an educated guess if you can provide a picture.
Luff Slide A109s (11mm diameter)
Clew slide B012 (12 mm diameter)
My question is when I measured my luff from the old sail on the ground it was a full 12 inches shorter. I would assume that is bolt rope shrinkage and not being pulled exactly tight. I have a Bimini that was pretty much copied from Sumner...Thanks for that
My concern is with the extra foot (or perceived foot) it is going to be rubbing the Bimini or maybe not...just not sure. Is there anybody else out there that has noticed a difference in luff dimension when ordering new sails. My boat is stuffed into the garage and everything is tucked away for the winter. Its minus 30 and I'm not really keen on setting everything up and taking perfect measurements, Pretty sure my mast hasn't been shortened. I could measure the mast though does anybody know what it should be?
Thanks
Dave
Luff 24.67'
Foot 10.25'
Leech 26.2'
Tack offset up 1"
Thanks
Dave
