I am currently corresponding with a sailor who has had his 2001 boat since new. It has 2600 hours on the Yanmar engine/Kanzaki transmission and the transmission has failed. I would consider this premature failure. For the last 12 years, this sailor has been sailing with his transmission in reverse because he read on the internet that it causes less drag than a spinning prop. As of 2008 a Yanmar service bulletin recommends sailing in neutral.
This idea drives me nuts. And you always read of people referring to the spinning helicopter rotors. That is not even a close comparison. A spinning helicopter rotor causes more drag than a locked rotor because it is spinning the opposite direction creating lift. Sort of like sailing with the engine running in reverse.
Forget about drag. Check your owners manual first. Then check with your engine/transmission manufacturer for any service bulletins. If you want to reduce drag, buy a folding or feathering prop(if compatible with your drive train)
Because of this sailors location, he may end up spending upwards of $5,000 to install a new Kanzaki transmission.
If you still disagree with me, buy a shaft brake. Do not depend on your transmission to lock the prop.
