Transmission Problem on my 10.7
Hi Paul, I believe we talked a while back about something, can't remember, but my wife say memory is the second thing to go. My 10.7 is a 79 with the Yamaha Q20 something for power. The diesel runs great but the tranny hesitates when backing out of my slip and shifting into forward. Even when going straight, if I put her in neutral say to slow down an approach to docking, then deciding to spped up just a little, it takes about 5 or 10 seconds for forward to engage. You can hear it engage as the motor slows down a little. Very strange. I talked with some old Yanmar engine guys who suggested my "throw" on my shifter was not going far enough even though it clicked in. They might have been correct as I adjusted the throw on the shifter and actually got thing to go almost a full 90 degrees from the neutral position on the transmission. The tranny still hesitates to imediately engage in forward. Ever heard of this before? I changed the tranny oil and that did not do anything either. I am hoping someone has a cheap solution like put sawdust in it or something. Do you know if I can remove the transmission without pulling the boat out of the water and removing the engine? I just did a stuffing box job on it and we needed to put my son in a wheel barrel postion with me holding up his legs while he squeezed his arms into that little rear door thing behind the engine. Any info from you will be greatly appreciated. The 10.7 has been a great boat for us and we are hoping it can be around for a long time. regards, Bill Zajac 321-868-3426email: bill@etsnet.com
