- Oct 22, 2014
- 23,853
As we splash our boat from a crane or rip the wrapping off like opening a Christmas present in June and run the trailer down the ramp, hoping not to become the star in a video montage of "Greatest Launching Mistakes", the question is are we ready to handle our boat?
Boat handling is kind of like riding a bicycle. It is pretty easy when the sea is calm and we are in the middle of the bay. But put a boater in the narrow waterway with 5 other boats all trying to get in or out of the marina for fun on the water and pucker factor goes way up for many of us. I like to exercise my skills when I get back on the boat after a bit of a rest. (it has been over 2 months for me.) Like stretching when you get up. The knowledge is there but the timing can be a little off. One idea is to start the season with some exercises.
How about putting prop walk to work for you this season?
Do you remember which direction your boat likes to lean?
Prop walk or prop wash causes you boat to turn more easily in one direction over the other. Yes prop walk can help you or cause you headaches. Better to do a little refresher while at the dock then to push off and find yourself about to rub sides with that "Million Dollar Baby"
owned by "Pain in the tuchus" in the other slip...
With the boat securely tied to the slip, turn on your engine and put the boat in gear at slow idle. Look over the side of the boat. Which side has more prop wash coming out from under the boat, that is the side your prop likes to push the boat away. If that is Port then your boat will spin more easily to Starboard, or visa versa.
Besides running my boat up to speed and testing the ability to power stop
(Trying to stop the boat within a length and a half, going from full ahead to full astern - take your time shifting gears. No need to blow your transmission at the start of the season
) I like to practice turning my boat around within it's own length. A great tool when your trying to get in or out of your slip. Being able to spin your boat around within the boats own length can be helpful when your trying to get to the fuel dock and you are approaching on port side and you suddenly remember the fuel tank is on Starboard.
Reading a BoatUS magazine from 2019, I came across this cool graphic.
www.boatus.com
Perhaps it is time to give it a try again.
Boat handling is fun.
How To Pivot A Single Engine Inboard Boat On Its Own Length
Mark Corke shows how to pivot a single engine inboard boat in its own length without even turning the wheel. Check out our 360 video!
