As a new sailor I’m interested in learning more about this topic.
I sail on Lake Pontchartrain, New Orleans, and the area is prone to fast developing and potentially powerful thunderstorms. It will not always be possible to avoid getting caught in one and I expect it's just a matter of time before I do.
Now I've read a bit on the subject and I think I understand the basics: Avoid heavy weather if possible. Reef early, more is better than less. Any port in a storm, find safe harbor if possible. Flatten the sails to reduce power, reduce angle of attach. Better control will be maintained on a 2 sail vessel if both sails are used (assuming reefing or a storm jib). Slight weather helm is desired, avoid lee helm.
Now I don't claim to know (without experience) my ability to achieve any of these goals, but I'm working on that.
I've also read (and here is my question) that unless you're an in tropical storm force winds, 90% of heavy weather encountered can be sailed on the desired course (keeping in mind the above points).
My question is, for a novice sailor wanting to return to port topside up, would it be better to sail on a close or broad reach in heavy weather? My reading seems to offer contradictory advice. In one article a broad reach was recommend unless the waves were fast enough to break over the transom, then the recommended correct course of action was to heave to.
Most articles, however, did not specifically say but described techniques for maintaining a close reach, bow pointed 45 degrees into the wind (and waves). This seems more intuitive and is how I was taught to handle large waves from my power boat days.
What I want is to prepare a plan of action if and when I get into this situation, and I would like to have confidence that the plan it is appropriate.
Thanks,
kpg
Thanks,
kpg
