Negative People?
Give me a break.This guy has no experience and just started to learn how to sail. Granted, he certainly has the courage to go where others may back off, but common sense dictates here that prudence needs to be practiced and I believe its a risk for a novice in an older smaller vessel in prime time hurricane season to attempt a trip like this across the Gulf!!! You can figure all kinds of "how much wind on a given day needed over a given distance" all you want, the fact of the matter is you are encouraging an inexperienced sailor to attempt a feat that requires knowledge, experience, outstanding equipment and a seasoned crew, all of which I have witnessed none mentioned by the author. If I knew Craig, I would sit down over a beer and discuss every negative versus every positive, and so far on my list the negatives outweigh the positives. If however, as suggested earlier he was too try the ICW wherever possible, that is far more feasible to me regardless of how much time is needed. The bottom line is then, if you want the boat in Galveston by a certain time, make the time!! Bob
