Thanks, Stu
That's a good idea. But I am thinking more about making the best time while cruising. I'm also saying that while close to the wind, I don't see the need for VMG. If the boat is setup right for the wind (watching the sails, windex, telltales, and heel) then it's about reading and responding to waves, gusts, calms, and shifts, with an occasional sail trim adjustment.
Or am I missing something?
I'm learning from this thread that there are differences on a run. There are far fewer cues from the wind, heel, and telltales. The waves can easily push you far off course. And, the best course to steer may not be obvious, because sailing higher may significantly increase speed, and VMG.
