Safety considerations
I single-handed my C-36 for the first time, last weekend in Buzzards Bay. I had no concern about sailing it, but I was concerned about my safety, and that of others. 1. I rigged jack lines for port and starboard, and wore an inflatable vest with integral harness. I clipped on whenever I went on deck. 2. I kept a good lookout, especially under the jib. I had one collision course incident with another sailboat; I was headed South on a starboard tack, he West on port tack. I saw him while quite far off, he apparently never saw me. I finally had to change course to avoid a collision. 3. File a float plan with someone who will know what to do when you don't return on plan, or are unreachable via VHF or cell phone. 4. Go slow! I don't mean the boat, I mean don't run or leap, you'll hurt yourself. I keep smashing my knees on the main winches leaping out of the cockpit - I have to keep telling myself to slow down. 5. Figure out in advance what you'll do if:a. engine fails in channelb. firec. floodd. collisione. injuryf. fall overboardThat said, some means of securing the helm is really necessary, as when taking a leak or setting or furling sail. An autopliot is nice, but a good helm lashing system will work fine. It should not be something flakey and makeshift, it should be easy, solid and reliable. My boat when trimmed properly will sail close hauled on a constant heading forever, it seems, with just the wheel locked, no autopilot. Experiment with sail trim and helm lashing 'til you can get her to sail straight for a while. This is how Joshua Slocum went around the world alone 100 years ago. Raising the main needn't be done head to wind as long as there is low enough friction going up; you can just drift about with the main sheet fully eased and raise it, then sheet in and go. The jib can probably be raised underway; I unroll mine on any point of sail, and can, in fact, furl it using a winch while sailing if need be. Its a lot easier to fully furl while headed up though. Lazy jacks on the main would be great - I don't have mine rigged yet, so I had to stand on the coach roof and gather up the sail as it dropped. This is probably the most dangerous thing to do. If you can rig lazy jacks, do it!Regards,jv
