Revamping Interior
Sean,we sail a 78 H25 and several years ago decided to redo the interior.The old upholstery fabric came off easily when we pulled and the dryness was evident.We used scrapers(putty knives,paint scrapers,etc to get all of the old foam off.Shop Vac came in handy.After cleaning,we used auto headliner material(appx $6.00/yd,6ft wide)as a replacement material.Fairly easy to work with(the foam backing provides some ridgidity and hides rough spots in the fiberglass walls.Use the 3M headliner adhesive,not the heavy duty spray which bleeds through.We made patterns with butcher paper,cut the pieces,and agonized far more than the actual placing.Must have used 12 -15 cans of spray,which costs more than the fabric.Get the fabric from an auto supply place,not the boat catalogues($17).Some trim work with 1/4 round,screen beading,etc really led to a great finish.The headliner material insulates,reduces noise and looks great... a big improvement from the upholstery look of the original.Our H25 had upholstery material on the shelves which we replaced with counter top laminate.This project tested a relationship but resulted in a great sense of a "job well done".Good luck on upgrading "an old girl".
