Always thinking sails are the last technology to be updated in the wing world I wonder if hang gliders although less popular, get more innovation applied due to safety consideration. There are also many records being broken for time aloft and distance flown.
Its interesting to note the similarities and differences.
Over all the newer hang gliders have high aspect swept back wings. Cut the glider in half and we're left with what looks like a headsail.
One item to note is the difference between the where the draft is located. Its really hard to find a good picture of a hang glider cross section. I did find a couple assembly videos. Like sails hang gliders have full length battens. These battens dont need to reverse so they have a permanent shape.
I'm looking at these battens and see that the max draft is in the first 10%- 20% of chord length. Most sails i have seen go towards 40% of chord (from front to back).
Anyone have a jib or mainsail with similar designs?
The attached photos show some battens and a decent wing section.
One other thing...while looking this up it was noted that for the newer high aspect wings, telltales are placed about 25% of the way out from the "root". This correspondes to 25% up from the boom. This seems to he the best indicator for stalls. Is there experince to back that up in sailing?
PS. Hope you are enjoying your sailing season. Pretty tough to get motivated to float the 170 with this summer heat, spurious winds and random thunderstorm.
