Sail upgrade
Jul 21, 2013
43
Oday 25' tall rig warwick, RI
I'm going to put a roller furling on my 25'O'Day tall rig.I wanted to know if my present jib can be converted to fit the roller? Can it also have the "protective" band put around it? What is the normal cost ? And does anyone know of where i can get it done in RI/Narragansett bay area?
Thanks
HRJ
Pat
Jun 7, 2004
1,250
I had my 140 genoa (roller furling) headsail cut slighly smaller as it is often quite gusty in
Kansas....I had Doyle's loft do the work and it is very high quality sail....just a little smaller....I contacted their Salem Loft, but not it connects to their Marlblehead loft I think. They also installed a new sun screen to match my doyle stackpak mainsail cover. Good Luck
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Hank on jibs can be converted to roller furling. Any good sail loft should be able to do this for you. Ideally, you'd want them to add reinforcing patches on the foot and leech, corresponding to common reef points (ie. for a 135%, you'd want reinforcement at about 110%, and maybe down to 90% for a storm sail.) Otherwise, it will prematurely stretch your sail. As for Sunbrella leech strips, your common sailing conditions should dictate. I often sail in lighter winds, and I'd rather not have the extra weight on the leech of the sail, potentially preventing it drawing. (Heck, for those conditions, I'd do well to have a light weight drifter, hah!) Therefore, I'd consider a jib sock over Sunbrella leech strips. A good sock would have criss-crossing bungee to help prevent oscillation in the wind... If you do go with Sunbrella strips, don't use white. I have seen pictures documenting that white Sunbrella gives terrible UV resistance compared to colored Sunbrella.
Once you get a quote for all these mods to your existing sail, you should weigh the age and condition of the sail - you may find you're better off just ordering a new sail built to your specs. Depends on how old, worn, and stretched your existing sail is...
Brian
TLW
Jan 15, 2013
271
Oday 31 Whitehall, MI
Regarding White UV cover on leech:
Most often, I believe, when white is desired it is Dacron that is used. "Sticky-back" Dacron, or Insignia Cloth, is used (regardless of color) because it is LIGHTER weight and would always be my choice.
Nov 9, 2012
2,500
I just did a Google search for "Rhode Island sailmakers" and came up with 7 distributed on a map.
Do the same and start makin' some calls…
Doyle, Thurston, Hood, North, Quantum. One of 'em will do it, and is close enough to you…
Brian
Jul 21, 2013
43
Brian
Thank you, I will.I was away & using my phone for email & searching so i'll work on it later.
HRJ
Nov 9, 2012
2,500
I'm with you! I HATE trying to web browse on my iPhone unless I HAVE to. Pinching and zooming and moving around to see everything is a PITA! :D:D:D
Brian
HRJ
Ward H
Nov 7, 2011
3,833
Just to give you an idea of costs,
I have a 110 jib that I am having the UV cover replaced. Quote was for $320 IIRC.
I was quoted something like $900 for a new main and $1100 for a new jib. I believe new sails from this site were about $100 cheaper than my quote from the local loft.
