Curt: I'm glad you found my Sail Trim Chart helpful. Please refer to the Quick Reference Sheet that was enclosed with your Chart and which identified the sail trim controls for the main and jib that are used to adjust draft depth, draft position, twist and angle of attack. Mast bend and outhaul are primarily used to adjust draft depth (belly). As you decrease tension on the outhaul you are increasing the draft depth. When you bend the mast you are flattening the sail and reducing the belly. As you've noticed, when you adjust the outhaul, the draft position moves also. The reason for that is that mast bend and outhaul are also 2 of the 5 adjustments for draft position. The other 3 draft position controls are the boom vang, Cunningham and mainsheet. By INCREASING tension on the 5 draft position controls, you move the draft position forward and by DECREASING tension you move the draft position aft. So it is a balancing act and that is the reason you have all the sail trim controls at your disposal. It is like adjusting a 4 barrel carb on your car. You have to fiddle with all the jets to get it right. For example, assume you ease the outhaul. That increases the draft depth (belly) and also starts to move the draft position aft. Suppose you don't want the draft position aft. To compensate, increase tension on the boom vang, Cunningham and mainsheet and move the draft position forward to where you want it for the wind conditions you are sailing in.Your in-mast furling system works the same way you other system worked. There is no difference. Also, the free-footed aspect is really no different than the bolt rope system.If I've confused anyone with the terms draft depth or draft position, they should go way, way back in the archives to where I furnished a detailed description of these items. In order to get 100% efficiency from your sails, it is necessary that you completely understand draft depth, draft position, twist and angle of attack. Those 4 items are what sail trim is all about and if you don't understand them, sail trim will always be confusing.
