Metal Close Pin
At the local hardware shop, I found a small metal close pin that is exactly the same size as the track in the mast. It works like a charm! I found that the L-shaped pin from Hunter elongated the track, & kept falling out. My close pin slides up approximately 2 inches from the opening in the track, doesn't hurt the track, & is easily removed if I want to take the sail off the mast.Cheers,Rick
