Wilhelm, I think I got it now. I really appreciate the help. Jim
AlbinVega@yahoogroups.com [mailto:
AlbinVega@yahoogroups.com] On
Behalf Of WL
Sent: Monday, January 28, 2008 1:47 PM
To:
Subject: Re: [AlbinVega] Re: Sail stop
Hi Jim;
I have a hole (actually two holes, one on either side of the track) and
I use a pin with a small line connected to the mast (so it won't fall
down). When I want to take the main off, I just take out the pin. For
storing the main on the boom, I roll up the main (on the boom) and use
the main-sheet to keep the main on the boom. I start at the far end of
the boom, and then loop the main sheet around the boom toward the mast.
Then I cover all with the sail-cover.
I don't raise the boom. I have another pin in the track for the boom,
about 3 inches below the top stop. If you like that pin also, then raise
the main as far as it goes up to the top of the mast, then pull down and
put the pin about an inch or two lower. I have a chackle to tension the
mast (downward, plus that way you can also adjust the luff). The line
goes up to that shackle and then down to a block on the mast. I sail
almost 100% single handed, and so far all's just right.
Wilhelm. V-257
PS. A note to Bob Vogel. Hi Bob, I'm back from my almost two months
'vacation'. It was very relaxing.Thank you for your holiday wishes. Two
days ago I went out with my boat- it was on that terrible foggy day-
visibility was about 100 feet. The engine started right away, I didn't
run down any channel markers, so I guess this will be another good
sailing year.
Happy sailing! Wilhelm
jkitchens1317 JKitchens@...
mailto:JKitchens%40kitchensfirm.com wrote: Wilhelm, I see how that
should work. I think in order to drop the
sail as close as possible to the boom, I'll need to raise the boom on
the lower track when storing the sail. Is that what you do? Thanks
for your help! Jim
