Sail slides
Jerry Gerber
A sail slide (slug) broke off on my 1995 Hunter 26. Where can I get a replacement? I ordered the smallest size available from West Marine, but the base of the slide is too wide to fit into the mast groove. I tried the North Sails web site, but they don't seem to have it available, either.
Sep 25, 1999
601
Hunter 23.5 Indian Lake
sail slides,
I ordered new slides for our h23 and also found the base did not fit the mast track, I went to the hardwareck and got a small grinder wheel to fit my drill and simply removed enough plastic to make it the right size then finished with fine sandpaper to make smooth again, not sure, where to get the size u need, hope this helps, good luck Mike B
N
Norm Steffen
Been there & done that. Try Sailrite out of Columbia City, Indiana. I think you want the cat # 23307. Hope this helps. N Steffen
