Mainsail Hard to Raise?
Hi, Bill. We assume that you are asking this because raising the main has become a big-time resistance training exercise.We have a 340 with standard main, and early on discovered that raising that main could be a real chore. The solution actually involved several things.As Doug mentioned, we spray our sail track lugs with "McLube Sailcote" about every 3 to 5 raisings, or whenever it gets difficult. It really helps.In addition, we had to make certain that sail raising was not constrained by our own running rigging. Before trying to raise the main we make certain that the vang is slack. Then once we start raising and the top two battens are past the lazy jacks (so they won't snag) we loosen the mainsheets. We found out that it is all too easy to make main raising a real chore by having mainsail rigging tight while trying to raise. Good luck!Carl and Jules/v 'Syzygy'
