Sail Slide Key
165
None None None
Last week we went to the lake for a wonderful sail and as I was bending on the main (due to a bat problem I've been stowing the main down below) I realized the sail slide "key" was no longer attached to the string at the mast. Fortunately, I looked down and there it was liying on the deck. That may very well be the first time something fell to the deck and didn't proceed to a watery grave!
I retied the key to the string and off we sailed. The string is quite worn and I need to replace it or find another place to attach the key. I didn't spend a lot of time looking at the fitting on the mast, but it appeared that the design doesn't allow itself to be replaced.
Has anyone addressed this small but important issue?
Sep 21, 2010
39
Hunter 23.5 Ocala
I took a lanyard that used to be used as an outboard safety cutoff line (had an extra). One end I clipped to the key, the other I clipped (somewhere) to the boom. My boom goes below every time I trailer up. It's fallen off or I've dropped it a few times with no worries.
