All,
After a few years with a 155, I've raced this past season with what Doyle says is a 107 headsail. I still have periods of excessive weather helm (wheel with up to a 180 degree turn) with apparent wind around 15. We are constantly adjusting the traveler, vang the main, let the sheet out, and adjust the genoa cars. We re-tuned the rig to what we feel is correct and only have a slight bend to starboard above top spreader we just can't make go away. So the question is, if the main causes weather helm, can having a too small headsail make the situation worse? Will going back to the larger headsail counter the large main and balance the boat out better?
Thank you,
Randy
Thank you,
Randy
