RF Sail Conversion
Hi Mike welcome to the Doyle Sailmaker Forum.Conversions of hank on genoas to Roller furling are a common thing. Any experienced sailmaker can do the conversion, but you will need to supply some information.You will need to give the sailmaker, either the proper size for the luff tape, or the make an model# of the furler you are putting on the boat. Most furler manuals will state the proper tape size for the furler.Next, you will need to provide a Maximum luff length of the furler between the Sail attachment points, which are the shackle on top of the furler drum, and the shackle on the bottom of the head swivel. This should also be explained in the manual, but your sailmaker can talk you through or provide you with a measurement form. Third, the side of the sail you want to put the cover on, and the cover color.Cost will normally be time and materials, but most sailmakers can estimate the cost pretty close.
