Towing with a Trailblazer
Here is more info on the tow of a H-260 from Tulsa, OK to Las Vegas, NV with a 2002 Trailblazer. The Trailblazer was rated to pull 5,700 pounds but that number should be closer to 4,000 pounds. Shortly after leaving Tulsa I got a "Service Engine Soon" light. I called GM using OnStar. They checked the computer and told me they could detect no problem. The next day climbing into Albuquerque the car was really struggling. I called OnStar and they directed me to a dealer who worked on the car for about four hours and told me they could not fix it. For the rest of the trip lots of things started failing including the cruise control and the radio. Climbing through Searchlight, NV I started getting heavy white smoke out of the tail pipe but it did not last. Then the automatic fan failed and the engine started getting so hot I turned off the air conditioner. The engine did not overheat but I did since it was 100-degrees outside. I decided I could not trust the vehicle so I traded it in on an Avalanche. It was ten months old at the time. Any other questions you can email me at F105PLT@AOL.COM
