There is a great problem with multiple headstays - differential (unpredictable) tensions in each forestay when one or both sails are flying. This somewhat relegates the use of multiple headstays to downwind sailing where the shape of the luff isnt important.
For upwind where the luff shape MUST match the expected sag (to leeward) of the wire, one really needs a means to quickly vary the stay tensions to 'match' the luff hollpw curve that the sail maker cut into the sails. Without such means, and with two stay 'sharing' the reaction loads from the backstay(s) the shape 'result' is always god-awful - draft aft, powered-up, inability to point, very slow boat and a boat that aggressively heels. Hyfield type levers dont have the rangeability to accomplish the varying tension requirements. Multiple head stays really require 'additional' backstays, running backstays, or complicated other means to adjust the stay tensions - especially underway. Multiple headstays are for boats that primarily 'go downwind', such as boats that are 'on passage'.
With two headstays, the windloaded sail always transfers it stay load to the 'furled' stay thus always becomes 'unloaded'. Plain vanilla tensions in EACH forward stay should be in the range of 15% as that what a sailmaker EXPECTS it to be. When you have 2 forward stays, and one backstay at 15%, the result is both the forward stays will be at ~1/2 that tension (7.5%) .... and the SAG in each wire will be well beyond what the sailmaker cut into the leading edge of the sail (luff hollow), expecting 15% stay tension. Not a good match between the stay sag and the luff shape; hence, deplorable foresail shape & operating performance.
