Sail boat blocks and load factors
Is bigger always better?
Intuitively we know without a block, sheave or low friction ring the line will rub on the boat parts, be harder to pull, or chafe and break.
The answer in many situations is to use a block.
Blocks come in many sizes, shapes and made from different materials.
The basic design is simple. There is a housing holding the block together, a center pin and a wheel or sheave that rotates around the center pin.
The burning question: How big of a block do I need. Let’s focus on the forces involved. I recently discovered this Harken tech site tool that provides their engineering knowledge to help us address this issue.
https://www.harken.com/en/support/tech-articles/block-loading-vs-angle-of-deflection/
The deck organizer is found on many of our boats. It is used to direct the line from the mast base to the cockpit. It is an example of a block. The line is turned by this block. Most often the angle turned is shallow (for example 30 degrees). The block used in this example will experience a load equally to 52% of the load on the line. It is no wonder that the low cost white plastic sheaves wear down and break after a few years hauling the sails up the mast.
There is the issue that you need to work out for your own boat.
What is the force involved on the line?
Armed with the load force on the line and the angle of deflection (the angle you are turning the line) you can select a block the will provide years of safe service on your boat.
Ok I said you have to figure out the force on your running rigging.
Wind Pressure per Square Foot = (0.00256) x (Wind Speed in mph)^2​
For a 500sqft sail, 10 mph = 128 pounds of wind pressure​
I know why me? Why do I have to do it? Just tell me the answer. I flunked freshmen HS math. I just want to sail.
If only it was that easy....
I did find a site to help ease your pain, published by the Rigging Doctor.
"This will lead you to selecting a capable and comfortable line." the Rigging Doctor​
It will help to ease the process. This article was written in 2015. The links to Harken and New England Ropes do not work. The rope breaking strengths and pricing should be verified with the rope source you are planning to use.
The article refers to Harken load calculators. Harken has changed their support system. Here are the new calculators links for the mainsheet and genoa.
The New England Ropes link was changed to a description of the various rope materials available. It can be found at this link.
Safe sailing.
